Grinding noise in H axle
Illinois Farmal
06-28-2006 20:39:24
This afternoon while getting ready to mow pasture I noticed a grinding noise coming from the left axle housing of my H. It wasn't continuous but sounded like something was rubbing at one point as the axle rotated. I greased the fitting on the axle but didn't lesson the noise any. Any ideas as to what is causing this? Thanks.
IH fan
12-31-2009 06:26:12
 Re: Checkrow planting and cultivating in reply to LenNH, 12-30-2009 15:45:45
[quote="LA in WI"](quoted from post at 00:59:43 12/31/09) Picture this scene with wire-checked corn:
Just before sunset.
Clear skies.
Slight breeze.
Corn about 6-10" high.
Freshly cultivated.
You are looking from east end of field, with sun glistening off (or thru) the leaves.
You can see all kinds of geometric rows, at many angles.
Beautiful. Just beautiful.
It sure was... although Dad quit check-row planting by the late '40s, I still remember seeing it well into the '50s, at least in NE Iowa. I know Dad never used check-row after going to a mounted planter on the C, I think in 1950, but it had the roll of wire with the planter. When Mom left the farm (mid-'90s) there was a very nice pull type 2 row IH planter left in the barn with the wire and it didn't look like it had ever been un-rolled or the stakes pushed in the ground.
Janicholson
06-29-2006 04:18:01
 Re: Grinding noise in H axle in reply to Illinois Farmall, 06-28-2006 20:39:24
Several potential causes exist.
If the unit has noise that is cycling at wheel rates (once per turn) it may be a wheel bearing. Which is wheel removal and, depending on some factors, removing axle housing from main casting, Bull gear removal, and effort.
If the nois repeats at many times the wheel rate, it is probably in the brakes. and is still serious, but easier to fix. Broken springs, or pieces of metal, or debris. Lets hope it is brakes. JimN
john *.?-!.* cub owner
06-29-2006 19:58:36
 Re: Grinding noise in H axle in reply to Janicholson, 06-29-2006 04:18:01
check bolts that hod rim to wheel. don't ask how I know.
