H Carb / Manifold
IndianaRed
07-01-2006 05:23:43
Having trouble lining up my manifold and carb. I can get one bolt in, but the carb is smaller than the manifold. Has someone replaced my carb with a smaller one, or am I not seeing something right? Can get the outside bolt on, but the inside isn't even close.
MAGMAN
07-01-2006 06:12:02
 Re: H Carb / Manifold in reply to IndianaRed, 07-01-2006 05:23:43
Maybe it has a SH or 300 manifold on it if it does it will take the bigger M type carb. JON
IndianaRed
07-01-2006 08:22:04
 Re: H Carb / Manifold in reply to MAGMAN, 07-01-2006 06:12:02
I got it. Just had to cheat the first one a bunch. Now that I've got it running, I'm noticing it's hardly responsive at all to the throttle. 1/2 to 3/4 of the way nothing. Last 1/4 or so starts to rev up. Springs in gov?
RustyFarmall
07-01-2006 10:43:56
 Re: H Carb / Manifold in reply to IndianaRed, 07-01-2006 08:22:04
Did you get the tang on the governor rod inserted into the slot in the throttle shaft?
IndianaRed
07-01-2006 10:44:50
 Re: H Carb / Manifold in reply to RustyFarmall, 07-01-2006 10:43:56
Never took it apart.
CNKS
07-01-2006 11:05:31
 Re: H Carb / Manifold in reply to IndianaRed, 07-01-2006 10:44:50
The connection between the carb and the governor rod is the one in question not the one at the other end next to the governor -- if you did not get it lined up right, it will do an you described
CNKS
07-01-2006 11:05:04
The connection between the carb and the governor rod is the one in question not the one at the other end next to the governor -- if you did not get it lined up right, it will do an you describeds
old
07-01-2006 09:13:50
You probably need to adjust the govenor to match the carb. In the I-T manual it explains how to do that and it has to be done almost any time you change carbs or rebuild a carb
IndianaRed
07-01-2006 10:46:45
 Re: H Carb / Manifold in reply to old, 07-01-2006 09:13:50
Bought tractor as is. It must've sat for sometime. Have never installed carb or gov. Just fixed up engine to get rid of bang, (broken piton), and this is where I am now.
