W30 magneto timing
Ben Sanders
07-03-2006 10:16:08
Gentlemen,
I have a friend with a late 1920's W30 engine that he uses for his equally old sawmill. He's looking for information on magneto timing for the engine. Anyone able to help?
Thanks,
Ben
KEB
07-03-2006 11:23:28
 Re: W30 magneto timing in reply to Ben Sanders, 07-03-2006 10:16:08
First, bring #1 cylinder up onto compression, and set to top dead center. Make sure the rotor on the magneto is pointing at the #1 spark plug terminal. Set the timing such that the impulse trips a little bit AFTER top dead center - if you set it to trip too soon, it'll kick backwards when you crank it. You make find adjustments in the timing by aligning the bolt holes in the coupler - they're spaced a little bit different on the two pieces so that the some pair will aling with small changes in the relative position.
Running timing is set by rotating the cover on the end of the magneto (with the arm attached).
Keith
Ben Sanders
07-05-2006 08:38:33
 Re: W30 magneto timing in reply to KEB, 07-03-2006 11:23:28
Keith,
Thanks for the info.
Ben
