46 h gear oil leak
Eric in Maine
07-08-2006 17:47:10
My h started leaking gear oil from the top of the transmission.It would leak down both sides of the transmission,just in front the clutch and brake pedals.PTO seals? Thanks for any help!
Nebraska Kirk
07-08-2006 20:58:41
 Re: 46 h gear oil leak in reply to Eric in Maine, 07-08-2006 17:47:10
Does the oil appear to be comming from between the rear of the belt pulley attachment and the rear gas tank support? If so, there is a stamped steel plug in the rear of the belt pulley attachment. That plug may have a hole in it. That is what happened on my H. Gear oil was leaking from between the rear of the belt pulley attachment and the rear gas tank support. At first I thought the gasket was leaking so I installed a new gasket, but it still leaked. So, I took off the belt pulley again, and then I noticed that that steel plug had rusted through. Put a new one in and it has not leaked since :-)
dcw in N.B
07-08-2006 18:01:40
Might be transmission cover gasket,if it has one.Someone may have used sealant at one time in place of a gasket.When I did my 41 H,I ordered a gasket for the cover from the local Case IH dealer,but it didn't fit properly.
