backfire/pooh?
iester350u
07-13-2006 19:12:08
rebuilt 350u small pops / backfires less noticed at higher rpm. gas,dist,[Was points but changed to electronic] no change in pops/backfires could dis shaft be cause? any thoughts appreciated,Thanks
kfox
07-14-2006 05:32:41
 Re: backfire/pooh? in reply to iester350u, 07-13-2006 19:12:08
Camshaft slightly out of time?
old
07-13-2006 21:02:29
A lot of times that problem is caused by carb problems and it running way to lean. I'd try adjusting the carb and see what happens you may find that you can't adjust it which means you need to rebuild it. I see that problem all the time because of junk in the tank and it getting in to the carb and clogging the main jet
magman
07-13-2006 20:18:13
How about an intake leak lean condition? JON
Ned22
07-13-2006 19:23:55
Make sure you have valves adjusted properly.
iester350u
07-13-2006 20:01:06
 Re: backfire/pooh? in reply to Ned22, 07-13-2006 19:23:55
I set them .017 ??
