rear main seal plate on farmall H
SLH IN MO
07-17-2006 19:40:09
Just over hauled my H. Now i have developed a leak for the second time behind the rear main and oil pan plate in area where the two rubber plugs are located looks like the oil is coming form under the plate in the seam area is there a quick fix without pulling the oil pan and plate again.THANKS FOR ANY HELP
CNKS
07-17-2006 19:55:16
 Re: rear main seal plate on farmall H in reply to SLH IN MO , 07-17-2006 19:40:09
I have the same problem to a lesser extent than you. I suspect it is the rear seal, requiring a split. I did replace the rear seal, but that was my first one, I probably did not do it right. I replaced that plate twice, if I remember correctly.
