Drawbar interchangeability
Rock_Picker
07-19-2006 09:31:44
I have a drawbar taken off a Farmall 300 row crop tractor. What other models will it fit? thanks in advance..... ..... ..RP
Hugh MacKay
07-19-2006 19:52:19
 Re: Drawbar interchangeability in reply to Rock_Picker, 07-19-2006 09:31:44
Rock Picker: Having once installed a Farmall 300 axle clamps and U on a SM, here is my conclusion. Bear in mind the swinging drawbar is specific to certain models. Some of these folks will try and tell you M, through 560 is heavier, not so, there were two drawbars, "Standard and optional heavy duty. I agree, most M, SM, SMTA, 400, 450 and 560 had the heavy duty drawbar, but it was also optional on H, SH, 300, 330, 350, 340 and 460. Even though swinging drawbar was model specific there were light and heavy duty for all models.
How do I know this? In 1972 I removed the fast hitches from my Farmalls 300 and 560 and ordered from parts two new optional heavy duty drawbars for those tractors, complete with axle clamps, U and swinging drawbars. All parts for both were identical, except the swinging drawbar. Even the rollers for the swinging drawbars were identical.
Don L C
07-19-2006 18:08:50
The Drawbar parts on my M are about 30% heaver than the drawbar on my H, ant no way are they the same.....
CNKS
07-19-2006 20:09:08
 Re: Drawbar interchangeability in reply to Don L C, 07-19-2006 18:08:50
I think the original question was: What other models does it FIT? As Hugh said there were different options.
CNKS
07-19-2006 17:22:26
The U-shaped part will fit the C through at least the 560. The swinging part is model specific. I have had a U-shaped drawbar on a C, the same drawbar was installed on my 460.
Aces
07-19-2006 10:48:32
Rock Picker I would say h through 460 the H 300 460 should have smaller axels then m 560.
NDS
07-19-2006 11:52:09
 Re: Drawbar interchangeability in reply to Aces, 07-19-2006 10:48:32
Axle housings are same size IH made them this way so same cultivators, planters, etc. could be used. I have drawbar fron 460 on M fits perfect.
NDS
07-19-2006 10:36:51
The horseshoe drawbar that bolts to axle will fit H through 560 some of the bigger tractors will have thicker metal.
