Old Bent Iron
Coax
07-19-2006 21:00:41
Once again I come to the Oracles of IHC to gain Knowledge of things unknown(at least to me!)I have a 240 utility w/a 3pt.Fast Hitch on it, and I"ve purchased a new Implement for it.(A post hole auger,)I"ve Discovered that the Lift Arms are bent in about 1 1/2" So nothing Fits...24 1/2" spacing....So the Question,are these Hitches cast or forged???I don"t want to heat this thing and have it shatter while bending it back into shape..any ideas??? Thanks.
CNKS
07-20-2006 17:40:22
 Re: Old Bent Iron in reply to Coax, 07-19-2006 21:00:41
You can purchase fast hitch to 3 point hitches, see the link for one source. If someone has already converted yours (improperly), you can also buy the lower plug in arms shaped to the correct 26" cat 1 width.
Janicholson
07-20-2006 12:30:36
If the lift arms you speak of are on the tractor, there are cast parts in the system that are breakable. The 3point is not a fast hitch, that is a 2point. If it is a two point with 3pt conversion prongs in it then the hitch needs to be heated and bent outward to match a standard IH Fast Hitch spread so other FH implements will spear in correctly. Pictures would help if what we are saying is all wrong. JimN
IaGary
07-20-2006 04:54:03
Coax I've not seen any 2pt impliments that have cast arms.
You should be able to bend them back into place.
Put a jack between the arms and spread them.
Gary
