656 wide front end
Don656
07-20-2006 21:02:39
Does anyone know if a front end from a 806 is the same as the front end for a 656?
ny bill
07-21-2006 08:53:18
 Re: 656 wide front end in reply to Don656, 07-20-2006 21:02:39
i believe the bolt mounting patterns are the same. i saw a 656 hydro once that had a 706 front axle. i'm using the spindles and hubs from an 806/826/756 (salvage yard parts) on my 656 loader tractor, as the bigger tractors have beefier bearings and spindles. i'm using the 656 knees.
Aces
07-21-2006 08:51:57
Don656 Yes except for one thing the wheel bearings are bigger for the 806 than 656. So if you wish to use the same hubs off the 656 they will not fit if you use the 806 hubs on the 806 front end ok.
