McCormick Deering 15-30 22-36
Andrew from Aus
07-23-2006 06:45:21
Hello,
Just want to know whether pistons and sleeves from a later 22-36 would fit a 1926 15-30 tractor. If anyone out there has actually fitted them in practice.
Thanks
Andrew
El Toro
07-24-2006 09:02:56
 Re: McCormick Deering 15-30 22-36 in reply to Andrew from Aust., 07-23-2006 06:45:21
Hi Andrew, I reeived an email from a man in the next county that sells engine parts. He said the
sleeves and the pistons are direct swap from the 22-36 to the 15-30. Hal
PS: He has new piston rings too. $79.00
El Toro
07-23-2006 11:13:40
The 15-30 and the 22-36 used the same block, the 22-36 may have used thinner sleeves to get the 4.75" bore. There is a man not far from me that has a set of the 4.75" rings. I can contact him on Monday to see if the pistons and sleeves from the 22-36 will fit the 15-30. The block on the 15-30 may require boring oversize if thinner sleeves were not used. Hal
Andrew from Aust.
07-24-2006 02:28:49
 Re: McCormick Deering 15-30 22-36 in reply to El Toro, 07-23-2006 11:13:40
Thanks,
I've seen some new pistons/sleeves/rings for 22-36s come up and wondered whether they would actually fit. People are quick to tell you they will but things change in reality!
I appreciate your help.
Regards
Andrew
El Toro
07-24-2006 03:52:30
 Re: McCormick Deering 15-30 22-36 in reply to Andrew from Aust., 07-24-2006 02:28:49
weberstractorworks.com has a sleeve and piston kit
for the 15-30 for $900.00. Hal
Andrew from Aust.
07-24-2006 18:35:32
 Re: McCormick Deering 15-30 22-36 in reply to El Toro, 07-24-2006 03:52:30
Thanks for your help!
I wanted to be sure before I spent any money on bits. Nothing worse than finding things don't fit!
I appreciate your time to help me out.
Regards
Andrew
El Toro
07-24-2006 19:21:50
 Re: McCormick Deering 15-30 22-36 in reply to Andrew from Aust., 07-24-2006 18:35:32
IH must have used those sleeves and pistons from
the 22-36 in the 15-30. I have the Nebraska Test Data and they ran a test on it. Here's the web site that has all the IH tractors and that 15-30 is on page 2 with 425cid engine. Hal
http://www.oldoakfarmalls.com/IHRANKbyHP_1.html
