Letter series axel length?
Mike CA
07-24-2006 11:28:56
As I'm poking around the internet, I came up with this pic of an H. But look how are the axels protrude outside the rim! Why is that? Is this an extension that can be removed, or is this the way some H's were shipped.
CNKS
07-24-2006 17:39:17
 Re: Letter series axel length? in reply to Mike CA, 07-24-2006 11:28:56
Maximum standard tread width on the H was 80 inches, optional 100 inches.
randy hall
07-24-2006 15:17:55
the standard lenght axle on an h will stick out past the rim a little with the wheels set clear in.
Hugh MacKay
07-24-2006 13:00:39
Mike: Most standard axle lengths on H or M was 84" from side to side. It was a bit shorter on some older Hs. The axle Allan speaks of is the optional 100" axle and when he states "country" he actually means his part of the country, Those long axles were almost standard equipment in some parts, especially where beans, beets and some other vegetable crops were grown. Very likely your going to find a lot of long axles in CA.
Come EAST young man, and we will find you all the standard axle Hs and Ms you want.
Mike CA
07-24-2006 13:08:19
 Re: Letter series axel length? in reply to Hugh MacKay, 07-24-2006 13:00:39
How long do you think it will take me to drive said H back to Cali? hehehe
Hugh MacKay
07-24-2006 16:12:21
 Re: Letter series axel length? in reply to Mike CA, 07-24-2006 13:08:19
Mike: Well, Andy makes it all sound quite exciting. Being 64 and having already seen more than a few of those 10 hour days in a tractor seat, I'm not sure I share the same exuberance for the journey.
I remember a story, few years back of a guy from the bottom 48, pulling a small travel trailer behind his tractor north through Canada and on to Alaska. I understand right now we have a guy crossing Canada via a W4 and tent trailer. I can assure you, you will see far more countryside from a tractor seat than from a Buick.
NDS
07-25-2006 07:54:39
 Re: Letter series axel length? in reply to Hugh MacKay, 07-24-2006 16:12:21
You guys worked "Bankers Hours" we always ran at least 12 hours in land preparation and planting season and often 16 or more hours.
Hugh MacKay again
07-25-2006 11:01:56
 Re: Letter series axel length? in reply to NDS, 07-25-2006 07:54:39
NDS: One thing I forgot to mention, my banker now works 24-7. Now, I haven't tried him at midnight, but I know he's there as late as 10:30pm and as early as 4am, so I'll give him the benefit on the rest.
Hugh MacKay
07-25-2006 10:48:17
NDS: Let me assure you, I've seen my share of 16 and even 20 hour days. Yes I remember a few times going 40 to 50 hours non stop.
Andy Martin
07-24-2006 15:29:43
With big tires an H can make 18 mph.
If you enjoy ten hour days you can travel 150 miles, so take two weeks off and drive it home in ten days. That would be 1,500 miles.
Don't begin to think aobut engine wear. H's and M's used to get run ten hours per day all summer. If you are plowing 8 acres per day you'd take ten days to plow 80 acres.
It would be an interesting trip. I don't know what the fuel economy would be, but someone will help with that. I'd guess you could go all day in road gear on one tank, or 15 gallons, and it might do better than that, maybe 15 miles per gallon.
The real trip would be to do it alone with just a tool box. Having someone follow you would not only spoil the fun but would also cut the net fuel economy way down.
You would see lot's of the country with time to look! Long down grades would be a challenge, though, as a Farmall in road gear can get up quite a speed going downhill, even without an implement.
Mike CA
07-24-2006 15:58:31
 Re: Letter series axel length? in reply to Andy Martin, 07-24-2006 15:29:43
I was, of course, kidding.
As I'm sure you were. The bumpiness of the tires along would drive me nuts after 100 miles.
Andy Martin
07-25-2006 06:02:58
 Re: Letter series axel length? in reply to Mike CA, 07-24-2006 15:58:31
Bumpiness of the tires?
They are smooth and sweet.
I was only partly kidding. Roading a tractor is great fun, and like Hugh, I've spent many ten hour days on a tractor.
For a long road trip the main thing is wind and bugs in your face, and exhaust when the wind is just right. And it takes a lot of time. And your arms get tired.
They ride pretty smooth on good roads and really rough on bad roads.
It is dangerous. You have to have your wits about you and pay attention at all times to traffic conditions, road conditions, and your inability to stop quickly.
However, the view is GREAT and you really do see things you never will from a car or truck because you are going slowly enough to really see. You'll also meet lot's of nice people and lot's of idiots who don't have time to wait tow minutes to pass you.
All that said, I would never start on a long trip on a tractor I had not run for several hours and know the condition of the steering, brakes, oil consumption, and knew for sure the rust ahd been shaken out of the fuel tank.
Allan In NE
07-24-2006 11:37:37
All Hs in this country were ordered with the 100" axles so that they could handle the 6 row beet and bean crops.
Allan
