Farmall MD w/ M-W Hand Clutch
Jimmy Thelen
07-24-2006 15:59:52
I was wondering if anyone has any information on how an aftermarket M-W Hand Clutch works on Farmall MD. I am having problems with clutch slippage and am looking for adjustment advice for both the standard foot clutch as well as the hand clutch.
Thanks
Janicholson
07-24-2006 18:44:57
 Re: Farmall MD w/ M-W Hand Clutch in reply to Jimmy Thelen , 07-24-2006 15:59:52
To find out which is slipping easily, determine whether the PTO speed is staying constant with the engine, or the rear drive. If the engine clutch is slipping, the pto will slow when it slips. If the M&W clutch is slipping, the PTO will be turning correctly with the engine, but the tractor will slow down. If you can tell how fast the blades on a bushhog are turning with the sound and feel of the system (experience). then pull a bushhog into some deep stuff to see if the bush hog and the tractor slow at the same time. If they do, and the engine is still going at a higher speed, then the master clutch is slipping.
To check the M&W, start in high gear from a stop with the PTO turned on. Have a friend stand behind the tractor (on the ground, not riding) and watch the PTO. If the PTO spins up fast and the slipping occurs at the rear axle, it is the M&W that is slipping.
The MD clutch will need a 3/4 to 1" space from the front of the platform where the pedal hits to the clutch pedal arm where it has the stop. This is free play. If adjusted and still slipping, as tested above, it needs a clutch. Good luck, JimN
Nebraska Kirk
07-24-2006 16:16:55
I have a manual for the M&W hand clutch, I would be glad to mail you a photocopy of it.
