1066 air conditioner breaker
idontno
07-25-2006 20:38:42
Can someone tell me where the breaker for the air conditioner is on the 1066 i"m running?Mine keep tripping.Too hot to do without one..Thanks..idontno
ejr-IA.
07-26-2006 07:27:49
 Re: 1066 air conditioner breaker in reply to idontno, 07-25-2006 20:38:42
The circuit breaker is behind the right side battery access door inside the cab.
idontno
07-26-2006 05:31:35
Thanks Gary..... ..
IaGary
07-26-2006 04:57:48
Not real sure on that 66 series but on the 86 series all the relays are in the fuse panel which is between the clutch and brake pedals.
And if it resets itself after cooling down it must be a relay and not a breaker.
You can change the relay but if the new one continues to cut out,you probably have other problems such as blower motor going bad.
One reason for the blower pulling hard is a plugged cab filter.
Gary
