Order Farmall Cub Parts Online
Cub steering
Rich Griffin
07-27-2006 17:14:54
My Cub wants to pull to the right all the time. The frt tires are new with equal pressure and the brake is not hangin up. What adjustment must I make to correct this if any?
Thanks
Janicholson
07-28-2006 10:39:14
 Re: Cub steering in reply to Rich Griffin, 07-27-2006 17:14:54
Tire pressure can be a factor in pulling to one side. A bent axle, or spindle might also cause the symptom. Toe in is less important but a factor to set toe in jack on wheel and use a nail to scribe a line on the middle of the tread(use a jack stand or block to hold it steady while marking the tire/rib. Then do the other side the same way. Let it down. Roll the tractor forward a bit to put the tires in there running location (don't let it backup any or it won't work) then measure between the scribe marks at the front of the tires and at the rear of the tires. front should measure 1/8-3/16 less than rear. The scribe marks take out the tire and wheel mount irregularities)
For the bent axle issue, put then tractor on level concrete (or evenly tapered front to back, but definately level (with a level)) and use a level to assess the camber (how much the tire leans in and out from vertical) and caster, how much the front spindle leans back from vertical. You are not interested in a specification, you are interested in having the two sides the same. The camber should be positive (leaning out at the top about a half inch from top of tire to bottom) and the caster should be leaning toward the back about 1/4" on the hight of the spindle. Good luck. JimN
john *.?-!.* cub owner
07-27-2006 20:16:52
here is a link to pictorial on lining up the fornt end.
07-27-2006 20:20:03
 Re: Cub steering in reply to john *.?-!.* cub owner, 07-27-2006 20:16:52
that didn't work, so paste this into the link.
http://www.cleancomputes.com/Cub/Maintenance%20Tips%20and%20Techniques/Articles%20by%20George%20Willer/Aligning%20Front%20Tires/Aligning%20Front%20Tires.htm
billde
07-27-2006 18:25:00
sounds like you have a front that is toed out. Establish a centerline, each front should be toed in 1/8 inch measured at spindle height, forward of the spindle.
Yugrotcart
07-27-2006 17:48:29
Try adjusting your toe in, should be about 3/16 to 1/4 in.
