Did i get RIPPED on an 826???
JSHULL
07-30-2006 07:25:29
I traded my 656 gas in on an 826 diesel. When i checked it out/test drove it, everything seemed alright excePt for a couple small fuel leaks. It has a new bottem end rebuild and rebuilt injection pump.After i got it home i started noticing problems. When you put the tractor in any gear and take off at half throttle it goes, but acts like the TA is back, then 15 seconds later, without touching a thing, it moves ahead faster like you threw the TA ahead. Is there any adjustments i could make. or does this sound more serious like a clutch or TA problem? The TA does seem to work normal other than this problem.. Also, there is a bunch of oil seeping out of the exhaust manifold and running down the side of the engine...it just started this today- could this just be a manifold gasket, or is the head gasket blown and causing this?? I hope i didn"t buy a big lemon cause my wallet is getting thin already.. Any information would be GREATLY appreciated!!!
the tractor vet
07-30-2006 15:16:26
 Re: Did i get RIPPED on an 826??? in reply to JSHULL, 07-30-2006 07:25:29
Ok here i am , well as far as the slober the german diesels will do this . BUT it does not hurt to have the injectors checked for proper settings and spray patterns . Now as far as clutch and T/A adjustments go will do the simple things first . Clutch pedal free trave is 11/16th of and inch massured from the ft. edge of the platform to the back side of the clutch pedal . Next is the transmission brake and that is on the right side of the tractor the linkage runs from the clutch cross shaft down to the bottom plate on the speed transmission . You adjust this with the help of someone to push the clutch pedal down to the pedal stop . To make the adjustments first loosen the lock nut on the clevis ya need a 3/4 open end wrench , next is to make sure that the clevis will turn , there is a hairpin that holds the clevis pin in remove this pin and , now have someone push the pedal all the way down to the stop while holding the brake lever all the way back see if you can just slide the pin back in the clevis if not adjust out till the pin will just slide in . when ya have this done let the clutch pedal up and turn the clevis out one more turn , now this is not and exect adjustment as with age and ware on the whole linkage you may need to go and other half to a full turn out then reinstall the hair pin and lock the lock nut . Now her ya need to make sure that the red lite on the right insterment panel is working . THis lite will come on when you push the clutch pedal down whiel the engine is running or when you first turn the key on or when you shut the tractor down while the key is on . This lite also tells ya if you have a pressure loss in the MCV circut . so if the lite is working then this is what ya do to adjust the T/A dump valve , start the tractor and run at and ideal with the transmission in N and parking lock set yoou will look at the clutch linkage from the clutch pedal to the clutch cross shaft you will see a long 1/4 inch bolt hooked to the rod loosen this bolt up 5-7 turns the TELTALE lite should be out when you push the clutch pedal down to the stop and hold it to the stop , NOW TURN the dump valve bolt in slowly till the TELTALE lite comes on as soon as it does STOP let the clutch pedal up shut the tractor down then ADD ONE MORE TURN TO THE BOLT and lock it down . Forget what ever ya read about massurements on this adjustment and do it the way i have layed it out . Now one thing that i forgot to ask ya was does your tractor have a hyd asst. clutch ????? If it does then we will have to go back and explain the propper free trave adjustment on it as they can be a pain to do if ya have never done one.
Darrenh
07-30-2006 12:18:34
My guess is that If ta works the same in ahead & back its the main clutch that needs to be look at or check make sure that the valve on foot clutch is closing when the clutch is out.
I agree sobering fuel put her to work after.
Jim Allen
07-30-2006 12:16:30
My 826 slobbers like that too.I thought I had an injection problem, but at work (an 8-shank chisel plow), it uses just a skosh over 4GPM, so I don't think it has too many iisues. No slobber when it's good and hot. I never let it idle below 1000 rpms when not fully heated up and try not to let it idle for long periods at all, excopt on a cooldown after a hard pull. Put it to work as soon as possible and give it a "dynamic warmup." Use your block heater on cold days. Shut down when not at work, even if for just 10 minutes or so.
In addition to adjusting the TA linkage, adjust the clutch and dump valve. Make sure your hyd fluid is topped up. The Tractor Vet and KB-826 would probably also tell you to check hydraulic pressures. These two guys have helped me a lot on 826 info, so stay tuned for their chime-in on this. If you don't have a manual set order today or they'll bust your chops.
FWIW, even though my 826 has 8000+ hours, I really like it. It's amazingly fuel efficient for its power output.
Chris in Washington
07-30-2006 08:52:50
It sounds to me that your TA needs adjusting. The proceedure is described very well in the operator's manual. As for the oil? These tractors are meant to be worked hard. They will slobber oil unless you get them up to temperature.
RustyFarmall
07-30-2006 09:43:36
 Re: Did i get RIPPED on an 826??? in reply to Chris in Washington, 07-30-2006 08:52:50
I agree, the slobbering from the manifols is probably un-burned diesel fuel, not engine oil.
