IH Stationary Engine
texasoldiron
07-30-2006 08:17:21
Went to a farm estate auction yesterday. No red tractors, but I did buy a hit miss engine. Tag marked: "International Harvester 1 1/2 to 2 1/2 HP, serial no. LAA 6446". Missing a few parts I think, rusted out fuel tank, broken mag cap. Rest seems to be okay. Engine turns over about half way then stops. I have not gone any further, did not want to screw it up. Where can I find out any info on these? Parts, manuals, etc. ? I will take some pictures of it, and try to figure out how to post them here. Thanks.
Tom Windsor
07-30-2006 13:54:53
 Re: IH Stationary Engine in reply to texasoldiron, 07-30-2006 08:17:21
This is not a hit and miss engine.
the parts for it are readily available I would contact>Link
Please take the head off before you attempt any further turning of it and see if it turns freely then. If not, check the govenor linkage carefully --you will have go to into the back of the motor.
The fuel tank...it is it between the runners or sitting high on the end?
texasoldiron
07-30-2006 18:06:27
 Re: IH Stationary Engine in reply to Tom Windsor, 07-30-2006 13:54:53
The fuel tank is between the runners. Thanks for all the info. I bought it to save it from the scrap metal guys that were buying up all the junk and metal. I will look and see what it will take in parts, but may just sell it to a collector, and let them complete/repair it.
RustyFarmall
07-30-2006 11:31:32
Do a search for a website called www.smokstak.com
teddy52food
07-30-2006 11:11:36
Be careful. If it turns part way, & gets tight, it probly has a stuck valve. Check this before you break the rocker arm.
Mark L. Steele
07-30-2006 18:08:33
 Re: IH Stationary Engine in reply to teddy52food, 07-30-2006 11:11:36
Yeah, I will be carefull. I have been messing with old Farmall tractors for about 5 years, and know not to force anything.
