300U Tachometer--Full of Engine Oil
Kerwin
08-05-2006 18:48:40
I had posted a question recently about my 300U's tach acting up...today I discovered why. When I took the tach off the tractor and opened it up there was quite a bit of engine oil in it.
Now, the question is what's gone wrong that the oil is coming up the tach cable? The cable is only 3 years old, is there a seal missing somewhere or something else I've overlooked?
Any help is appreciated. I don't know if I'll get the current tach to work again (it's draining right now), but I need to solve the oil problem before putting something back in the dash. Thanks for the help.
Easy1
08-06-2006 06:30:44
 Re: 300U Tachometer--Full of Engine Oil in reply to Kerwin, 08-05-2006 18:48:40
When I bought my 300U, the tach didn't work. I took it off and found it full of grease. There is a zerk to grease the cable, but it is easy to overdo it.
Will Sick
08-06-2006 05:45:03
The oil seal in you ditributor drive is leaking.
Nebraska Cowman
08-06-2006 04:15:16
I'd say the seal is bad in your hydraulic pump.
third party image
jossette
08-05-2006 18:51:47
why is there oil in your distributor housing?????
