What's Happening?
oakmar
08-15-2006 18:05:37
was running the brushhog today. half of a 2 acre field done and the darn thing was slowing down! (bogging down) I was down to a 1 ft cut and killing it, checked the fluid levels and everything was fine, ran around the field for 20 min,s cutting push over and it started to sing! now knew that I could cut the rest! but what happened when it slowed down and would'nt cut????? ??
oakmar
08-17-2006 18:18:40
 Re: What's Happening? in reply to oakmar, 08-15-2006 18:05:37
was in heavy IVY, BUT it cut through it when it started to sing! The Farmall A is a mid 40's, the hog is a Kingcutter 48" has always done well in the past!! Just something out of the ordinary, happened abd do'nt know what!!!!! !!!
Brownie 45
08-17-2006 07:54:27
Clutch slipping somewhere?
IH2444
08-16-2006 05:38:59
Another thing, make sure you don't have a bunch of wire or something fouling up your hog.
IH2444
08-16-2006 05:37:41
Can you turn the friveshaft on the Hog and have the blades turn ? Sounds like a bearing going out or something like that to me. If it is the hog, if the hog is free then the tractor running the hog is sick.
MN Scott
08-15-2006 18:52:12
What model tractor is it?
jossette
08-15-2006 18:35:12
to wet of grass
blades not sharp
to fast in thick brush.
belt tention tight.
Treat it like the lawn mower for home
