cab solenoid faulty again
Centerplate
08-22-2006 13:49:28
On my 1976 International 1566, the cab solenoid is not supplying power to the upper cab. I have replaced this item a couple of times and this one is faulty again. Is there a solenoid I can get from an other supplier than CNH that will give me better service?
Thanks for the help
the tractor vet
08-22-2006 14:25:47
 Re: cab solenoid faulty again in reply to Centerplate, 08-22-2006 13:49:28
You can use a CV relay from a semi as they are a little heavier and the one that i have used comes from a International semi . i use to get them out of wrecked I H 's along with wire ends for fixen tractor wireing harnesses .
