350 I/H
Les Lanyon
08-24-2006 20:04:51
I have a stock 350 I/H and I am installing a front end loader on it ,can anyone tell me how to tie in the hyd.into the tractor,I am mounting loader cont.and need to get high preasure oil to and from it. thanks Les
MARK ROBKE
08-26-2006 20:22:15
 Re: 350 I/H in reply to Les Lanyon, 08-24-2006 20:04:51
YOU NEED THE HYDRA TOUCH CONTROLS THAT BOLT ONTO THE SIDE OF THE HYDRAULIC RESVOIR. THEY BOLT ON JUST AHEAD OF THE HYDRA TOUCH CONTROL FOR THE REAR 2 POINT.THEY WILL BOLT UP SIDE BY SIDE.THIS HOW 300S/350S WERE PLUMBED FROM THE FACTORY.THE HYDRAULIC LINES RAN OUT FROM THE BOTTOM OF THESE CONTROLS.
burnetma
08-25-2006 14:44:03
Mine had a seperate hydraulic pump running off a shaft to the front pully. Worked great and lots of flow.
Brownie 45
08-25-2006 05:24:30
Have one of the inside hydraulic levers control loader lift, & the other lever control the hydraulic bucket[ assuming a hydraulic bucket].
Janicholson
08-24-2006 20:36:28
Assuming it is a utility, not a row crop tractor, the hydraulic situation depends on what is there already. Again assuming it has a pump and maybe a fast hitch drawbar. The two front levers to the right of the seat are for add on hydraulic attachments. They should be plumbed in a similar manor to the FH cylinder for two way, and with a single hose for one way control. The single acting cylinder needs to be setup with the valve control switch set to single acting. A manual will help describe these connections, as well as limitations and switches. JimN
Magman
08-24-2006 20:07:23
I take it you have live pump at the distributor? JON
Les Lanyon
08-25-2006 19:51:18
 Re: 350 I/H in reply to Magman, 08-24-2006 20:07:23
Yes I have a live pump at the dist,but no controles up by the stearing wheel, just one down by the seat that controles the 2 point hitch.thanks again Les
