M Boster
Paul G. in Mn
08-30-2006 18:00:29
my main shaft in the front boster on my M was really loose so I traded shafts with a donor I had. The bottem is now tight but the top under the half round gear still is really loose. Im assumeing there is a bushing up there. Is that hard to replace? Expensive to replace?
randy hall
08-30-2006 18:14:43
 Re: M Boster in reply to Paul G. in Mn, 08-30-2006 18:00:29
yes paul there is a brass bushing in the top. it is not nearly expensive as the bottom one. i made a driver to install them.usually the shaft is wore some too so i turn the upper shaft to clean it up and make a bushing to fit. i guess i'm kind of perticular.
