M backfires when shut down
e-manhunt
09-01-2006 20:09:16
My 1940 M gives one loud backfire -pop- when i shut her down, Throttling all the way down before i turn it off seems to help. I changed points and condensor last thing before this problem started. I believe I got gap correct.
Also, it might be me but she sounds like she is running louder, too.
Any ideas? Thanks.
Marty Johns
09-02-2006 20:20:54
 Re: M backfires when shut down in reply to e-manhunt, 09-01-2006 20:09:16
your fuel adj. could also be set to rich, which may not have showed prior to your tune up, as it may have needed it then!
Cowman in Nebraska
09-02-2006 04:03:17
I'd say you have it timed just a tad faster than it was before you changed the points making it run hotter. Probably not a problem.
Will Sick
09-01-2006 20:31:21
Once you shut off the ignition the points really don't matter. Run the tractor at a fast idle a minute before you shut it down to cool the cyliners especally if it's been working hard.
Nat 2
09-01-2006 20:18:54
That kind of backfire is often caused by a chunk of hot carbon buildup setting off the gas/air mix in one of the cylinders. The cure for getting rid of carbon is to work the snot out of it :)
As for it sounding louder, those backfires can do damage to your muffler. I"d bet that it blew the baffle out of your muffler.
e-manhunt
09-01-2006 20:12:24
One more thing - ran great for a couple occassions after I changed points -- backfire just started today.
old
09-01-2006 20:57:03
 Re: M backfires when shut down in reply to e-manhunt, 09-01-2006 20:12:24
When you shut one down the fuel is still being sucked into the engine and if theres hot spots like carbon build up it will backfire and sound like a shhotgun going off. One thing you can do is work it hard for a few hours, or do a water mist in to the intake of the carb to clean up the cylinders. Or turn off the gas and when it dies turn off the switch
Nat 2
09-02-2006 04:19:47
 Re: M backfires when shut down in reply to old, 09-01-2006 20:57:03
Oh, I forgot about SeaFoam. You can get it at most big-chain auto parts stores. Get yourself an empty spray bottle like a Windex bottle or something, pour about 1/3 of the can of SeaFoam into it, then slowly spray that into the vacuum plug hole on the side of the manifold on a nicely warmed-up engine per the instructions. She'll smoke like crazy, but the SeaFoam will loosen up all that crud.
