f-12 plugs
Bill Geer
09-01-2006 23:56:57
Hi Guys I would like to know what spsrk plug,and gap works best in a 1938 F-12. I did a search did not find any thing
Thanks Bill
Marty Johns
09-02-2006 18:09:20
 Re: f-12 plugs in reply to Bill Geer, 09-01-2006 23:56:57
I have a mid 40's A, it has the D21 plugs, and I knew they either needed cleaned and reset or replaced! posted here last spring and was told .025 cleaned them with a pipe cleaner (ID) type wire brush and reset them, not much of a power increase! BUT the fuel saving's per acre is unbelievable! cut in half!!!!!
Shovelman
09-02-2006 05:47:06
Bill,
I have used Autolite #3076 plugs for years with good results. The last ones I bought were under $4. each, which is pretty cheap for a 7/8" plug. Gap at .025"
Good luck,
Scott
Fred Milner
09-02-2006 04:21:30
You can get the AC 3077 plugs fron NAPA over night. They are not very expensive there. You can get a hot plug or cold plug if you need it, they have the numbers. If the tractor is hard to start or runs rough the hot plug may help. I have some tractors with the hot plugs in them and they do a lot better. I have been using them for years with no problems.
Nebraska Cowman
09-02-2006 04:19:32
W20 is a good hot Champion plug. I get mine from John Brillman 610-252-9828
teddy52food
09-02-2006 03:56:23
I think they are a W something in champion. could be W 10 or W14 with a 7/8 thread . D21 have a 18 mm thread. Gap with a magneto should never be more than .025 .
Fawteen - Oops
09-02-2006 11:18:55
 Re: f-12 plugs in reply to teddy52food, 09-02-2006 03:56:23
Yer right, it should be a W.
Fawteen
09-02-2006 03:38:22
Champion D21 or AC3077
Fawteen
09-02-2006 03:39:13
 Re: f-12 plugs in reply to Fawteen, 09-02-2006 03:38:22
Gap at .035, if I remember correctly.
