M finally out of the shop after front end work...p
Turbos10
09-07-2006 17:27:21
[img]http://www.tractorshed.com/gallery/tphotos/a36463.jpg[/img]
For those interested, I finally have everything back together on my turbo M after a complete front end rebuild. I used a cotton trailer axle, porshe rack and pinion, 90 degree steering box, and did a tilt hood. Anyone have suggestions on a cool paint scheme. Obviously, the standard red top to bottom just does not fit ;).
Keith-OR
09-07-2006 18:50:27
 Re: M finally out of the shop after front end work in reply to Turbos10, 09-07-2006 17:27:21
Let see if I can get it up here for you.HTH
Keith & Shawn
third party imageLink loading="auto" style="width:auto;height:auto">
Turbos10
09-07-2006 19:03:45
 Re: M finally out of the shop after front end work in reply to Keith-OR, 09-07-2006 18:50:27
Thanks....how you do dat?
GordoSD
09-07-2006 17:55:59
I'm a big fan of flames. How about red background with white to lt yellow to lt blue flame paint job?
Gordo
Turbos10
09-07-2006 18:00:28
 Re: M finally out of the shop after front end work in reply to GordoSD, 09-07-2006 17:55:59
Hmmm....I have done flames before.
I did ghost flames on my race truck.....
Maybe a red base with the white, yellow, blue flames done in a pearl so they are semi transparent?
John M
09-07-2006 17:49:05
What engine is in there and where is the radiator?
Turbos10
09-07-2006 18:06:44
 Re: M finally out of the shop after front end work in reply to John M, 09-07-2006 17:49:05
The engine is Farmall 4 cyl. I am not sure since I have not been into it, but I think it is a C248. I have not found the C248 or C264 either one on the block, so I am not 100% sure. It actually has some other numbers on the block but I dont remember what they were.
The radiator is a tiny little car radiator tucked up in the nose with an electric fan.
CNKS
09-07-2006 18:22:12
 Re: M finally out of the shop after front end work in reply to Turbos10, 09-07-2006 18:06:44
It's a C248 if there are no numbers cast into the block. C248 was the first engine in the series, thus had no markings.
Turbos10
09-07-2006 18:34:44
 Re: M finally out of the shop after front end work in reply to CNKS, 09-07-2006 18:22:12
Thanks!
Turbos10
09-07-2006 17:37:56
[img]http://www.tractorshed.com/gallery/tphotos/a36464.jpg[/img]
Try this??
