farmall a serial number
GREGORY N NORMA
09-08-2006 08:06:46
need help dating farmall a. exactly where is the serial number on the seat bracket. if i can't locate it how else can i date the tractor. any help greatly appreciated Greg
Red Dave
09-08-2006 08:31:07
 Re: farmall a serial number in reply to GREGORY N NORMAND, 09-08-2006 08:06:46
It should be stamped on an aluminum plate on the inside of the left-hand seat bracket, unless it is a VERY early 1939 and then it may be on the pedal guard.
If it is a serial number less than (I think) 205,000 the engine serial number should be the same as the tractor number, assuming it still has the original block. The engine serial number is stamped on a flat, raised boss on the right side of the block, below #1 sparkplug, kind of behind the magneto.
