464 Rear Oil Seal
Seedsntrees
09-13-2006 08:21:25
How big of a job is it to replace the rear seal?
Mine is leaking about a quart every twelve hours.
Thanks,
Fromjb2
09-13-2006 17:48:29
 Re: 464 Rear Oil Seal in reply to Seedsntrees, 09-13-2006 08:21:25
Hi Seedsntrees, are you referring to rear seal on the crankshaft of a German D206 Diesel?
Tractor has to be split at clutch housing same as changing clutch. Remove flywheel etc. There are some special instructions concerning replacing the seal as there are 3 ways the new seal can be installed depending on original. So mark or remember how original was installed.
On my brother's 684 D239 engine(similar to D206)it was leaking engine oil about a liter a day and when we changed the clutch and had the flywheel off to be ground we noticed the 4 cap screws on the main seal were loose, so tightened to spec and hasn't leaked a drop in 3 years now.
JB2
Seedsntrees
09-13-2006 22:11:05
 Re: 464 Rear Oil Seal in reply to Fromjb2, 09-13-2006 17:48:29
Thanks, it is a gas engine. I think you are correct about splitting the tractor. I think I just might buy more oil at this time.I put perhaps 20 hours a year on it anyway.
Regards,
