SMTA Grille Source
Smitholm
09-21-2006 10:22:41
I'm in need of one of the above. I know OEM's got them, but are there less saltier options out there? Thanks in advance for your help.
Dick
brainerd dave
09-21-2006 12:49:04
 Re: SMTA Grille Source in reply to Smitholm, 09-21-2006 10:22:41
If they are the same as the regular Super M grill, there's one on eBay right now...currently $75.00
#290030628599
Wardner
09-21-2006 17:53:58
 Re: SMTA Grille Source in reply to brainerd dave, 09-21-2006 12:49:04
Not the same. Some of the late SM's had the two flat spots but the factory didn't cut the 1.5" holes. They are probably more rare than the SMTA grill. I've only seen a couple.
randy hall
09-21-2006 10:36:00
they are pretty valuable property. i have a excellent used one for $400.
Wardner
09-21-2006 11:57:32
 Re: SMTA Grille Source in reply to randy hall, 09-21-2006 10:36:00
I think they are being reproed. I am sure I saw the add in Red Power Magazine but I checked OEM Tractor Parts on the net and I can't find it. I believe all you get is the verticle part. The other part around the radiator outlet and hood isn't being made yet. Any top part from any M will work.
Perhaps somebody here knows the source. If not I will check some old issues of RPM.
Wardner
09-21-2006 17:44:19
 Re: SMTA Grille Source in reply to Wardner, 09-21-2006 11:57:32
OK, I found it. Full page ad on inside cover of Nov-Dec 2005 Red Power Mag.
OEM is making it and selling it for $289. It comes with the correct hardware cloth (screen).
As an option, you can send in a bonnet and OEM will clean and weld it to the newly manufactured lower part. No mention of what that service costs. Probably $100 so Randy is in the ball park with an original.
And to think I walked by a nice grill several years ago for $100 at a RPRU near Des Moines.
Call OEM @ 800 283 2122.
