Order Farmall Cub Parts Online
Farmall Cub flywheel question
T.R.K.
09-25-2006 19:00:30
I'm looking at the flywheel on the back of a UC-60 power unit. The flywheel has a shoulder with 6 bolt holes around it. The shoulder is about 1-1/4" above what I would call the 'face' of the flywheel.
My question is Would a Cub clutch pressure plate bolt to this bolt circle and work, or if I want to put a Cub clutch in it, would I have to find a Cub flywheel? It appears there are 4 bolts to the back of the crank and 1 dowel pin. Does this sound correct?
john *.?-!.* cub owner
09-25-2006 19:27:53
 Re: Farmall Cub flywheel question in reply to T.R.K., 09-25-2006 19:00:30
Never had any delaings with one myslef, but form what I understand a cub clutch will bolt direclty to it. depending on wat you intend to do though, theure may not be a pilot hole in the crank shaft, or a bushing in it to hold a lcutch shaft centered.
