speaking of weights
tn terry t
09-26-2006 18:42:07
what other models wheel weights will fit an h
GA Dave
09-26-2006 21:58:54
 Re: speaking of weights in reply to tn terry t, 09-26-2006 18:42:07
Now! I know I have one of them RED tractors with a "little bit of white" on it. IH 240 Utility. Heck! the Farmall 240 is the same tractor with 36" tires and narrow front end VS 24" on the IH utility with WFE. I just finished painting the fenders and 16'front wheel weights. Thank's all of yaw'll. David.
DCW
09-26-2006 18:50:57
Farmall C,sUPER c and M,sUPER m.
RustyFarmall
09-26-2006 19:23:57
 Re: speaking of weights in reply to DCW, 09-26-2006 18:50:57
Rear wheel weights are fully interchangeable all the way from the C and super C up to and including probably the last tractor built by IH. I have a set of the later split, two piece weights on one of my Hs.
tn terry t
09-26-2006 19:55:19
 hey rusty in reply to RustyFarmall, 09-26-2006 19:23:57
i have split weights for one side at this time they have slots on the out side edge is those used to "stack" more weights? thanks terry t
RustyFarmall
09-27-2006 08:50:05
 Re: hey rusty in reply to tn terry t, 09-26-2006 19:55:19
Yes, the slots are for bolts so that you can "stack' more weights. The owners manual for my H suggests that you should use extra long bolts and mount the first two sets of weights with the same four bolts.
