Oh yeah....and one more thing.......
Patrick martin
10-10-2006 01:32:16
Does anyone know if ANYONE sells a governor rebuild kit?????
Here's what I need. You guys know the little ball bearing on the end of the governor shaft?
Well I screwed up and lost the little balls that fit in the bearing. I need a whole new bearing and if there is a kit with springs and such then I'd like to get that too.
This is for my Farmall 100 as well.
Red Dave
10-10-2006 07:28:48
 Re: Oh yeah....and one more thing....... in reply to Patrick martin, 10-10-2006 01:32:16
Nobody has a "kit" that I'm aware of.
You will probably have to order each piece you need, but it's not all that hard to do if you have a parts diagram.
You can get them from your local Case/IH dealer, or from a place like Carter & Gruenwald who will ship them out to you. they are at>Link
Or>Link from Messicks at Link
gene bender
10-10-2006 03:04:04
Last thrust bearing i got from dealer was 14 and i think the spring was 8. How much slop does the input lever have? I rebush them and the throttle response is like new again.
Hugh MacKay
10-10-2006 01:55:14
Pat: CaseIH has every thing you need, don't think it comes as a kit though.
Patrick Martin
10-10-2006 01:56:41
 Re: Oh yeah....and one more thing....... in reply to Hugh MacKay, 10-10-2006 01:55:14
Do you mean like my local dealer or their site?
Nat 2
10-10-2006 11:48:10
 Re: Oh yeah....and one more thing....... in reply to Patrick Martin, 10-10-2006 01:56:41
Can you order direct from CaseIH? I'm pretty sure you can't.
Hugh MacKay
10-10-2006 02:54:33
Pat: I've never tried their site, but I expect anything available at dealer is also available there. The dealer here is quite close by and that is my reason for always going there.
