Govenor? no power
Ed B.
10-15-2006 16:43:05
Cant figure out why my farmall cub wants to stall out after its under a load for about a minute? It will run all day long with no problem,but soon as i go to mow the grass it wants to stall.(engine will smoke out of the oil dip stick). It started last summer,so over the winter i rebuilt the engine,(Timeing marks,timeing,and all other specs. are good. Cleaned govenor,didnt help. Tried different govenor,didnt help. Cleaned distributor, weights move freely (new tune up),didnt help. I still think the proublem is in the govenor but just cant figure it out. Any sugggestions? Thanks.
EZ
10-15-2006 17:09:06
 Re: Govenor? no power in reply to Ed B., 10-15-2006 16:43:05
How's your carb?
I was having some of the same problems, swapped carbs. and no more stall out.
Things to check:
Good gasket seal, good seal on the air breather to carb., float height proper, idle tube in place, free throttle movement...at the carb and at the governor.
Good luck.
ed b
10-16-2006 16:27:01
 Re: Govenor? no power in reply to EZ, 10-15-2006 17:09:06
Going to try a different carb. Thanks . Can you tell me what you mean by idle tube.
