Farmall Regular Crankshaft Pulley and Flywheel Nut
Wayne Ellingwor
10-19-2006 19:32:12
What type and what size socket do I need to remove the nut on the end of the crankshaft pulley and the flywheel nut? Or are there any other ways to get them off other than a chisel and a hammer?
Wayne Ellingworth
10-20-2006 13:12:02
 Re: Farmall Regular Crankshaft Pulley and Flywheel in reply to Wayne Ellingworth, 10-19-2006 19:32:12
I ordered a 3-1/2" socket for the flywheel nut. I have no idea what size the pulley nut is and deep reach sockets that big don"t seem to be very common or cheap. It seems to be about 2-1/8" but not exactly. It is hard to measure in there. What size is it?
Nebraska Cowman
10-20-2006 16:23:25
 Re: Farmall Regular Crankshaft Pulley and Flywheel in reply to Wayne Ellingworth, 10-20-2006 13:12:02
I had to run out to the shop so I measured one and it looks like 2 3/16 to me but I don't have a factory wrench that size to check it against.
Wayne Ellingworth
10-21-2006 19:43:26
 Re: Farmall Regular Crankshaft Pulley and Flywheel in reply to Nebraska Cowman, 10-20-2006 16:23:25
Is the pulley nut left-hand or right-hand thread? Will a deep reach 2-3/16" socket work?
F-Dean
10-20-2006 05:54:19
NAPA has large 3/4 inch drive sockets. I recently bought a 3 1/2 inch socket that works great on w-30 and 10-20 wheel nuts.
F-Dean
10-21-2006 06:53:45
 Re: Farmall Regular Crankshaft Pulley and Flywheel in reply to F-Dean, 10-20-2006 05:54:19
I used a 3/4 inch breaker arm with a 4-foot piece of pipe and stood on the end of the 4-foot pipe to get the nut loose. No damage to the socket!
Tom Windsor
10-19-2006 23:56:39
I welded up a socket out of flat stock...cause, once off, I need to put it back on without tearing it up.
TW
Tom Windsor
10-20-2006 00:06:20
 Re: Farmall Regular Crankshaft Pulley and Flywheel in reply to Tom Windsor, 10-19-2006 23:56:39
I failed to mention...the reason for the caution...I bought the nut that holds the flywheel on a JD-B last month...Just a little old thing...$16.75
Nebraska Cowman
10-19-2006 20:13:37
You can weld up sockets out of flat stock but yeah, I use a hammer and chisel. And I seldom find nuts that have not been removed that way before.
