!!Removal Of WD-6 engine!!
Tyler Cohrs
10-20-2006 18:23:56
Hi this winter i am going to put new seals and bearings in this tractor and would like to know the steps of removing the Motor. Thanks Alot.
Geoff NY
10-21-2006 05:01:28
 Re: !!Removal Of WD-6 engine!! in reply to Tyler Cohrs, 10-20-2006 18:23:56
Rear seal from Case?IH dealer was about $25. Front seal was $90. No big mystery to it, have at minimum an IT manual. There are better reference guides available. The parts books are a big help. It shows all the parts and their relationship to each other. Also is excellant when ordering parts.
Jaywalt
10-20-2006 19:39:50
You've got to be kidding? $150? for that you outta be able to find something/make something that would work. I think some of the older rear mains used some sort of felt rope?
mulcher
10-20-2006 18:49:04
Takeing the motor out is the easy part. Finding parts will be the hard part and they will be expensive. We have a WD6 that needs a rear main seal but just the seal is $150 so it still leaks.
Brian
