stuck
Tina Garcia
10-23-2006 16:54:03
I have a 1963 460 international tracter it is stuck between gears and I cant seem to get it back out any Ideas other than taking the top off the transmission.
Keevin
10-24-2006 11:00:28
 Re: stuck in reply to Tina Garcia, 10-23-2006 16:54:03
If you can remember what gear you was in and what gear you was going to , you may be able to get your shifter in both rails , half of it in one rail and half in the other ,and get them both back to neutral. I know because I can do that with my M. Hope it made sense.
the tractor vet
10-23-2006 17:03:15
Yep . Set the brakes and remove the three bolts that hold the shifter on and pull the shifter out then with a long screwdriver or prybar just line the one that is not lined up with the other two and set the shifter back down in the slot and put the bolts in .If it is stiff comming out just push in the clutch and it will come wright out , oh yea do this with the engine OFF.
Tina Garcia
10-24-2006 09:49:15
 Re: stuck in reply to the tractor vet, 10-23-2006 17:03:15
Have done this and so far nothing. None of the three will line up. They are all off
Janicholson
10-24-2006 12:20:16
 Re: stuck in reply to Tina Garcia, 10-24-2006 09:49:15
Tina,
The force required to move the rails might be fairly high. If two are moved toward one direction the third will be in the neutral location. The other two need to be aligned with that. Having someone rock the tractor forward and back (violently with the top of the rear wheel) while prying may do it. Pulling the top off of the transmission might be the final answer. But almost all of them can be freed up the way we have been describing. Be sure to have the tip of the shifter lever repaired to look like the one in the picture. Build it up with weld, then grinding it so that it just works is the best as it needs to be a tight fit in the slots (front to back) to prevent the problem from happening. Good luck JimN
Nebraska Cowman
10-23-2006 17:00:08
yes, all you have to do is take the shifter lever off and use a small bar or big screwdriver to line up the shifer rails. then build up the end of the shifter lever. third party image
