Live Hydraulic conversion for an H???
David Mikkelson
10-24-2006 07:25:01
Maybe there isn't a way... but is there any of the assessory drive mounted pumps (like the 300s) that will fit on the standard H front cover and assessory drive before passing through to the distributor?
I have a resevour and valve bodies, and even a generic 12 GPM 3000 psi pump... but coming up with a good way to drive it is questionable.
This old H has an old Freeman loader on it, but the 650 psi belly pump and old syle pipe in pipe cyinders do not give enough capacity.... not to mention thr trip bucket and the pain of dead hydraulics everytime you push the clutch in. I clean the barn with it... but its a pain...
(FYI, if I do use this pump with the old cylinders I'll limit it to 1200 psi).
Money for a different tractor is not an option... so no sense in going there.
Thanks.
vally farm
10-24-2006 19:07:49
 Re: Live Hydraulic conversion for an H??? in reply to David Mikkelson, 10-24-2006 07:25:01
I've been thinking about this idea for my stage 1 Sup H...put a sprocket on the front of the crank instead of a belt pully, but run the pump down LOW, behind the front wheel bolster. Chain drive will take off the side loade on the pump seals and give a no-slip system.Pull off the belt pulley and mount the Hyd. tank under the gas. I've talked to some friends and they all said NO, but couldn"t tell me why. I think this would give LOTS of live hyd power and be almost invisable. What do you guys think?.....Mike
dem45133
10-25-2006 05:59:39
 Re: Live Hydraulic conversion for an H??? in reply to vally farm, 10-24-2006 19:07:49
I like this idea.... although naturally I just scrapped out an old junk baler that had a bunch of #50 chain and sprockets all over...
I hadn't thought of the crank pin hole use with a roller pin... tractor didn't come to me with a crank anyway. I'll be looking into both.
But keep talking... this is good stuff.
Thanks
Dave
Hillsboro
Steven@AZ
10-24-2006 11:37:39
third party image
third party image
third party image
third party image
third party image
third party image
dem45133
10-24-2006 15:09:05
 Re: Live Hydraulic conversion for an H??? in reply to Steven@AZ, 10-24-2006 11:37:39
Hello Steven
I've though hard about belt drive... in fact I even planning to shaft it back along side the block and tuck the pump in almost entirely under the gas tank. In fact I've built most of it... but still need keyways cut. Most of those style pump bearing are not designed for lateral loads only axialary... This way a bearing block and rollers are carrying the belts lateral forces.
I never did figure out a good way to attach a second seive to the original "crank pulley". Did you weld that one? I looked at a original that was already off... just didnt seam heavy enough to be cast steel... thought it iron... which makes it hard to weld. Maybe I was wrong on this?????
I've also thought of a way to hard mount the pump's drive (shaft) pulley in line with the water pump... and use the water pump variable as the tightener. But then you have a three point belt system with only 1/3 diameter contact area on any one sieve. Since this is a high load, high tensioned belt though I'd be asking for trouble with slipage and on the water pump's bearing... so didn't do that.
With the pump back and low and a box type resevior under the seat using a super H seat frame, it would make a clean installation.
Just havn't figured out a good way to drive it... even looked into a cogged belt... but not enough clearance in front of the original crank pully to add a 1" wide cogged belt (pulley is about 1.25").
Even thought about modifying the waterpump shaft for cog... but its bearing is still the limiter there.
So.. as yet... its not finished. Just a pile of unused parts.
What ever I do I'll take pictures.
But I'd like to know more about what you did on the crank pulley modification.
Thanks
Dave
Hillsboro, OH
Steven@AZ
10-24-2006 15:51:03
 Re: Live Hydraulic conversion for an H??? in reply to dem45133, 10-24-2006 15:09:05
I got the idea for the extra crankshaft pulley from a Farmall 450 with the Char-Lynn power steering added on - extra pulley with a roll pin through the hole in the crankshaft.
Keep in mind that I can no longer crank start this tractor - there is no pin for the crank mechanism to engage.
I use a "B" width/section belt to drive the pump and I ordered a pump that is specifically designed for the side load of being belt driven (about $180). I get about 15 GPM at full throttle, which is plenty to run my power steering and raise/lower the mower.
I had to add on an oil cooler because the belly pump reservoir doesn't hold enough fluid to keep the temps down. I would still like to add another 3 or 4 gallons of fluid capacity some day.
A good welding shop can weld an extra pulley to your crank pulley. But beware that the keyway is going to carry the load. My system has a roll pin carrying the load.
I thought about modifying the front bolster to allow room inside it for a direct drive pump, but just didn't have the means at the time to make it work. In the future, I might still do that. :o)
If anyone has questions, my email is open...
CNKS
10-24-2006 08:05:35
Anything can be done, but if that pump was not actually made for the tractor, it will be difficult. People have taken a "generic" pump such as yours and run it off of a modified crankshaft pulley. I believe Steven@AZ did that, perhaps he will see this. His is a professional looking job. As noted below the pump from a Super H-350 will work in front of the distributer with minor modifications. M&W also made a pump, my understanding that they are hard to find. My M has one, it works fine. For a loader a larger reservoir is best.
Wardner
10-24-2006 10:00:24
 Re: Live Hydraulic conversion for an H??? in reply to CNKS, 10-24-2006 08:05:35
CNKS is right about aftermarket pumps. M&W was one supplier among several.
You should be aware that the IH distributor flange has a SAE #2 layout. That same standard is also used on many hydaulic pumps. You would need to find a pump with the flange on both sides so that the distributor could attach. I believe this is how one of the aftermarket tractor pumps is arranged. The other arrangement is similar to the IH live pump but has the correct bolt spacing for the tractor it fits.
I have all this stuff and I am thinking about running two pumps in front of the magneto just for laughs. It will require relocating the oil filter and crankcase ventilation pipe.
glennster
10-24-2006 07:40:36
i did a live conversion on a 48 m. the pump will fit on the front cover with the bottom 2 bolts lining up. the top two however will not. the kit i used was one i bought at an auction. there were instructions with it for the coversion. basically what you needed top do was put two bolts in the top holes, cut them off and file them smooth. you then mount the pump and redrill and tap new holes in the cover. you can do it without removing the front cover, however it is highly advisable that you go in and change the cam gear to one off a super h. my m lasted about a year and then broke the drive gear. the gears from the super fit, but they are much sturdier. the kit also had a plate that you would install on the belly pump housing that eliminated the belly pump and used that for the resevoir. i am going thru a super m right now, and i am going to add a live pump to that one. i plan on using the belly pump as the resevoir, but i am going to leave the lift all pump in it, so i have both one way and two way hydraulics. the belly pump used 30 wt motor oil, but i plan on using hy-tran, which is in my other tractors.
chuck46
10-24-2006 09:02:50
 Re: Live Hydraulic conversion for an H??? in reply to glennster, 10-24-2006 07:40:36
Hi, I have had a live pump on my 41 H for over 30 years, it works very well. You will need a pump from a Super H 300 or 350 and the port block bolted to the bottom of pump. To mount the pump, two of the holes will match, I drilled and threaded a third and made a simple clamp for the top left. You will need to rework the pipes from the port block to suit you. Mine has been used a lot with no problem from the timing gears. Good Luck, Chuck
