Red or White?
Doc Travis
10-25-2006 16:22:50
I have a 1957 350 farmall. Can anyone tell me if the sides of the hood and grill are white or are they all red. It looks like they were white from under all the rust but I have seen pictures with them both ways. I am trying to restore it back to original and painting the hoods are are about the last pieces of the puzzle.
Thanks guys, Travis
old
10-25-2006 16:35:32
 Re: Red or White? in reply to Doc Travis, 10-25-2006 16:22:50
From what I understand the 300 and 400 where all red and the 350 and 450 where red and CREam colored. Sorry but its not really white but an off white or cream.
Doc Travis
10-25-2006 16:42:05
 Re: Red or White? Carb adjust on a B in reply to old, 10-25-2006 16:35:32
That makes sense. By the way would you know how far out to set the mixture scew on a marvel carb. Thanks, Travis
old
10-25-2006 16:45:56
 Re: Red or White? Carb adjust on a B in reply to Doc Travis, 10-25-2006 16:42:05
Idle is set at about 3/4-1 turn out from bottom and the main jet about 3 turns out from bottom to start with. Then from there you have to adjust them for the most power and no black smoke. Some times that can mean the main jet is opened up to around 5 or 6 turns out.
Doc Travis
10-25-2006 17:35:57
 Re: Red or White? Carb adjust on a B in reply to old, 10-25-2006 16:45:56
Thank you, Thank you.
Travis
old
10-25-2006 17:37:48
 Re: Red or White? Carb adjust on a B in reply to Doc Travis, 10-25-2006 17:35:57
Those are just ball park settings and depending on where you live they can be set a lot differant but at least you have a good starting point to set them at
