Update on no spark.
merv
10-28-2006 12:46:26
F-Dean,JimN, El Toro.
Well, I fixed the problem.
As I mentioned, number three Tower had no continuity. So with a little bit of bailing wire technology. I solved the problem. I drilled a 3/16 diameter hole from the plug wire side of the cap through to the pickup side. I then took some copper welding rod and the good old torch. Heated up the copper, so that melted and drop through the tower. After it cooled down. I tested the continuity. And it worked.
I reinstalled the cap and hooked up plug wire and spark plug to check for spark. I have spark. Not as strong as I would like it but it's there. I have a brand-new condenser, and I'm going to install it. The magnets on the magneto, grab a hold of my screwdriver very well. So that is not a problem. Hopefully by the end of the day I will be back to pushing dirt.
Thanks for all your help and information. It definitely will come in handy in the future. And I for one them always willing to learn something new.
merv
El Toro
10-29-2006 04:45:19
 Re: Update on no spark. in reply to merv, 10-28-2006 12:46:26
Glad you found the problem and have your tractor running good. I have an old Wico mag that has lost the magnetism in the magnets. It would cost more to have the magnets recharged than it's worth. I have a picture where someone that had a mag on a farm tractor and he used an auto type coil and connected a wire from the new coil to the points. This bypassed the old coil and magnets. He ran a wire from an ignition switch
to supply voltage to the new coil since he had
battery start. It must have been 12 volts too since I saw a ballast resistor in the picture.
Hal
third party image
