Another 300 U Question
B Mark
10-28-2006 15:20:33
Thanks for the ansewers about the power steering on my 300 "U". I think I"ve got it figured out. Is there a hydrulic,or transmission filter or screen to service? This tractor has sat a long time. Are any reprint factory service manuals avalable? I have a I&T Manual but would like a more specific one. Thanks All!
Dellbertt
10-28-2006 16:47:39
 Re: Another 300 U Question in reply to B Mark, 10-28-2006 15:20:33
I have two 300U and changed the hydro screen in both. It is located under the seat. The drain is on the left side near front bottom.
Its a two man or one man and a hoist to lift the top half of the resevoir.
The screen is about the size of a paper towel cardboard wrapper. Be VERY careful when lowering the top back on as its easy to crush the screen and they cost between $65-100 if you can find one.
Clean the resevoir good while in there and you might put new o-rings in the valves.
I was luck enough to get an original parts manual and the original operators manual with one of them.
The screen number is 364687R91.
I would scan the parts pictorial for you but my scanner isnt working at the time.
The last parts book I bought at Case/IH dealer for a Case 1030 was $26 they might be more now but it is available and is what you need.
Dell
Dellbertt
10-28-2006 16:53:35
 Re: Another 300 U Question in reply to Dellbertt, 10-28-2006 16:47:39
If your screen is good and solid just clean it and reuse. Unless you can find one easy and reasonable.
