oil pump cover part numbers
werowance
11-01-2006 05:59:49
Hi everyone, i have a oil pump out of a super A c113 engine that im rebuilding, the potmetal cover plate is broken on it, and i have found another pump on ebay from an H. does anyone know if the cover plate is the same for both models, i know the pump is different where it bolts to the block, but its on ebay so i cant lay hands on it to compare without buying. international wants 116.00 for it new, so im looking for used. part number for what i need in the book is 6098D A anyone know?
thanks in advance.
teddy52food
11-01-2006 10:41:27
 Re: oil pump cover part numbers in reply to werowance, 11-01-2006 05:59:49
The plate from an H is bigger than the ones from A , B , C & will not fit.
El Toro
11-01-2006 07:40:28
This cover number 6098DA is off the Super C oil pump, I don't if the Super A's are the same. Hal
justin w
11-01-2006 07:27:13
I have a NOS one available, and the cover is actually still available thru your local Case IH dealer. Warped plates are common on the C113-135 engine oil pumps, so it isnt always a good idea to just buy a used pump or part that may have the same problem as your plate.
Bill Geer
11-01-2006 06:58:52
I have a old pump off a A 113 motor.
Do you need whole pump or the bottom plate.
I'am in ST Johns MI.The plate can be mailed. Bill
