Hydrolics rebuild 47 SA
Brett Chesshir
11-01-2006 06:22:56
I need to rebuild the box under the gas tank. The local IH dealer wants $101.00 for the kit, are there sources you guys use for these types of parts with better prices, I'm new to the forum, just bought my SA last week, any input would be greatly appreciated.
gene bender
11-01-2006 10:39:43
 Re: Hydrolics rebuild 47 SA in reply to Brett Chesshir, 11-01-2006 06:22:56
better check out the pump first cause if it aint working the rockshaft unit cant work. You can put a pressure guage in the line at the manifold where the lines go into the rockshaft. Small is pressure and the big one is return
Brett Chesshir
11-02-2006 08:12:05
 Re: Hydrolics rebuild 47 SA in reply to gene bender, 11-01-2006 10:39:43
the pump is good, when I lower the rear plow it lifts the rear of the tractor then pulls the motor down. The hydro tower just leaks real bad
VAJerry
11-01-2006 09:51:17
With all the o-rings, gaskets etc that really not a bad deal. Just take your time keep things clean. Not really that hard to do. Oh yea you don't use all the parts in the kit.
Brett Chesshir
11-01-2006 10:00:40
 Re: Hydrolics rebuild 47 SA in reply to VAJerry, 11-01-2006 09:51:17
thanks for the input Jerry, I never use all the parts to any kit..ha, ha, what parts won't i need? what part of Va are you from? I'm outside of Harrisonburg
VAJerry
11-01-2006 10:07:24
 Re: Hydrolics rebuild 47 SA in reply to Brett Chesshir, 11-01-2006 10:00:40
Bowling Green
