f-20 fan pulley and a couple of ?
whiskey river
11-02-2006 18:13:27
hey yall, i got a few questions. im tryin to finnish up an extended f-20 restoration and need some advice. first ? the bearings in the fan pulley are wore and let the fad wobble 'bout when running. i tried to match up some roller bearings to retrofit with no luck. any suggestions? also, my sp holes are in bad shape, is there any plug that mabee has a longer threaded portion with the correct opperating range? one last one. my fuel lines have chafed against things and need replaced. had any luck makin our own? what'd you do for the carb fitting? thanks guys
Farmallgray
11-03-2006 13:19:28
 Re: f-20 fan pulley and a couple of ? in reply to whiskey river, 11-02-2006 18:13:27
For the carb fitting, just unsolder it from the old line and solder to a new one. Get a good rolling cam tubing bender. Snap-on sells a nice one under their bluepoint brand for about $25. I have had one for about 15yrs and love it. Get plenty of extra line because it will probably take a couple tries before you get it bent perfect. If your tractor is a late one it should have the fittings with breakaway ferrules. These are still availble from CaseIH (same ones used on the letter series).
SproutW
11-02-2006 19:58:38
Forgot to comment on your spark plug holes. I would strongly suggest having your head taken to a machine shop and have them look at it. They could give you a better answer. Dealing with torn up spark plug threads and compression is not a good thing. They could heli-coil them to be on the safe side.
SproutW
11-02-2006 19:55:33
Try Gordon Rice. He has everything you need for the F-series tractors. I have atttached his website. I'm sure he will have new bearings for you and may even have new gas lines. If not Nebraska Cowman has just about every used part you need. One heck of an honest guy that will treat you just fine. Nebraska's link is http://nebraskacowman.com/
Good luck on finishing your F-20.
whiskey river
11-02-2006 18:15:45
forgot to mention the fan is the v-belt style. Thanks.
