Super H STEERING WHEEL
Al -VA
11-02-2006 21:18:24
I am using a wheel puller to pull my steering wheel on my super H. I am applying pressure with a 9 inch wrench. So far it has not moved. I have removed the nut but is there something else that holds the wheel; or do I need a little more leverage.
Thanks Al
GordoSD
11-03-2006 05:55:12
 Re: Super H STEERING WHEEL in reply to Al -VA, 11-02-2006 21:18:24
If you are going to replace the wheel, use your sawsall or 4 inch grinder and cut the hub lengthwise just down to the threaded shaft. It will pop right off.
Gordo
RR Mech
11-02-2006 21:24:21
They are usually very tight from rusting over the last 60 years or so. More leverage and sometimes a little heat from a torch will do the trick.
