WD9 injection pump on an MD
Brad in WI
11-11-2006 21:10:24
Will an injection pump off of a WD9 work on a MD with no to very little modifications. What type of gains or losses will occur. I have a friend that has 3 pumps laying around and I am wondering if it is worth my time to install on my MD for a little extra HP.
ncdiesel48
11-12-2006 06:46:04
 Re: WD9 injection pump on an MD in reply to Brad in WI, 11-11-2006 21:10:24
Yes It does work, I have one on mine. It takes a while to get it perfect though, the timing and fuel adjustment.
Brad in WI
11-12-2006 07:21:58
 Re: WD9 injection pump on an MD in reply to ncdiesel48, 11-12-2006 06:46:04
Was there any power increase. What did you have to do to the fuel adjustment, up or down. Just want to make sure I do it correctly if I decide to do it.
ncdiesel48
11-12-2006 16:38:40
 Re: WD9 injection pump on an MD in reply to Brad in WI, 11-12-2006 07:21:58
You kinda just have to feel your way around, dont mean to sound like that but it took us a while to get it right. I will say this though the tractor will start right up on diesel after it has warmed up of course, it never did that before. If there is a horsepower increase we havent noticed it yet. The governor is a lot jumpier.
Brad in WI
11-12-2006 19:09:18
 Re: WD9 injection pump on an MD in reply to ncdiesel48, 11-12-2006 16:38:40
I am going to try to put it on a PTO dyno with the MD pump and then with the WD9 pump and see if there is any changes. also want to get it running where most HP is available.
