Ultimate in tractor stability
Harley
11-13-2006 14:53:02
Finally got the 9 bolt hubs and pressed steel wheels and 15.5X38 rears on the M loader tractor and now the only thing I have to worry about is getting between gate posts on a 16 ft. gate. Set them out to 104 inches. That's with the hubs all the way in. Couldn't turn them around cause the weights wouldn't fit over the hubs if they were on the outside. Gonna be stable for these here hills down here that's for sure. Should quit diggin with those wider tires too. Been a good day in the shop, Harley
How?
11-13-2006 16:27:02
 Re: Ultimate in tractor stability in reply to Harley, 11-13-2006 14:53:02
How wide is your front axle? Surely not 104 inches, which means it'll still "trike-roll" on you if ya have too much lift on loader on steep ground. I'm sure ya know this but be careful. Nothing about an M says "low profile" or low center of gravity.
Hugh MacKay
11-14-2006 19:40:47
 Re: Ultimate in tractor stability in reply to How?, 11-13-2006 16:27:02
I"ll bet the center of graviety on Harley"s M is lower than most utilities. Wheel tread is one of the most effective ways to lower graviety. Most of those dual wheel tractors will slide sideways down a hill before they upset. If your expecting a wide front to stop roll over, your dreaming.
Hugh MacKay
11-14-2006 19:40:15
IaGary
11-13-2006 16:22:07
Harley
Do you plan on chasing mountain goats with the M or leveling mountains? LOL
But it should be stable doing either one.
Gary
Allan In NE
11-13-2006 16:10:18
Good For You Bud!
Would sure like to see a picture of that wide-angled outfit. :>)
Allan
Paul Shuler
11-13-2006 15:26:16
Glad to here someone has some stability in their life. I don't think I will till my teenage daughter grows up a little. Matter of fact tractors are about the only stability I have these days. Good to see your post Harley
Paul
russ hamm
11-13-2006 16:16:51
 Re: Ultimate in tractor stability in reply to Paul Shuler, 11-13-2006 15:26:16
paul, i lived through 2 daughter and can feel your pain. it gets better. hold the beer as much as you can and good luck.
