Trans oil change in a Super A
Brett Chesshir
11-16-2006 05:49:15
I bought a SA a few weeks ago, i need to change the fluid in the tranny. I drained it at the PTO. Is this the fluid that goes to the gears that turn the axles. Or is the fluid in the axles seperate? How do I drain the fluid at the axles, pull the pan under each axle? What fluid do i put back in, gear oil or Hy-tran? I just rebuilt the hydro tower and used Hy-tran
billde
11-16-2006 06:42:51
 Re: Trans oil change in a Super A in reply to Brett Chesshir, 11-16-2006 05:49:15
There is a drain plug for the trans under the tractor, draining the pto does not drain the trans. remove the final drive pans to drain, replace gaskets. fill plug is right above where the pans attatch to the drives. use 90 wt or 85-140.
Hy-tran is correct for the hydraulics.
gene bender
11-16-2006 06:42:31
yes pull the pans then fill with 90wt.
