300 to run smooth
Dick Davis
11-21-2006 15:15:04
Hadn't run the 300 for 2 months, battery was up, wouldn't start, pulled with M, started and ran very rough - not even 3 cylinders full time - gave it a shot of starting fluid - smoothed right out and ran good for a minute. Jumped on and killed it(RATS), wouldn't start, pulled it, ran rough again, starting fluid, smooth right out. Why?
That is my hardest to operate tractor the H&M's 6 volt are nice compared 12 V 300. Thanks for your wisdom, Dick Davis
old
11-21-2006 15:59:38
 Re: 300 to run smooth in reply to Dick Davis, 11-21-2006 15:15:04
Sounds like you have a gummed up carb. Pull the drian plug and the main jet. Then spray carb cleaner into the main jet and let it drain out the drain plug. Then close it back upand see if that helps
Dick Davis
11-21-2006 16:34:37
 Re: 300 to run smooth in reply to old, 11-21-2006 15:59:38
Thanks old I'll try that tomorrow AM. Dick
