Duals again
Wardner
11-25-2006 18:10:48
As some of you may know, I am not a farmer. Heck, I only have five acres. I suppose I could do as Mike Dukakis advised and grow a cash crop of Belgium endive but how do you sell the stuff. Although Mike used to be my Governor, he is not exactly a neighbor who might frequent my roadside stand.
Anyway, I like tractors and if they are unusual I like them better. I think a 660 with factory duals would qualify. While the idea of duals from Gempler's sounds interesting, I would really like to use the IH hardware.
So in that light, I am including the parts book illustration of the duals that fit a 660. They do not fit a 560 standard tread nor does the book list any for that tractor. If anyone has a lead on those parts, let me know.
third party image
I am also including two pictures of my 660 wheel. I can't be sure how the "drum" attaches to the wheel. Does it replace the existing wheel-to-rim bolts or does it use the other eight holes (with square recesses) not currently being used. Are my existing rims with the riveted lugs no good for this application. Would I have to get four new rims? We are now talking about alot of money over and above the parts in the previous picture.
third party image
third party image
Assuming the factory set-up is not available new or used, or the total cost of doing it right is "outta sight", would a Gempler's solution work with my wheels and rims. I have an extra set of tires but would have to get 2 rims. Hugh indicated that a spacer would have to be welded to the new rims so I suppose any 34" rim that would work with a 18.4 X 34 would be satisfactory.
What additional hardware would be required over and above the tires and rims? Would the extra eight holes figure into the installation? Can I forget about J-bolts and lever clamps. Would I simply weld new lugs to the new spacers? What should tire wall to adjacent tire wall distance be?
Are my 660 wheels similar to anything that came later starting with the 06 series? In other words, could my dual setup be transferred to another tractor?
Hugh MacKay again 2nd
11-27-2006 05:12:23
 Re: Duals again in reply to Wardner, 11-25-2006 18:10:48
Wardner: Another idea I looked at 35 years ago was 656, and having duals spaced for corn planting 30" rows using a second set of cast wheels. Farmall 656 has same wheel as SM, 400, etc. Axles were not long enough to give spacing I wanted. I never did do this, by the way. My idea was to get an axle stub about 12" long, clamp it in outside wheel, weld a snug sleeve to it that could slide over tractor axle. Then I was going to find a heavy wall pipe same inside diameter as outer circumference of wheel weight mounting holes. I then planned on putting long bolts through both inside and outside wheel.
I expect you could do the same with that 660, with the exception of the axle shaft coupler. I figured the axle coupler would make it stronger, should outside wheel take all the weight.
With regards to snap on duals. I have seen the snap on duals wear the inside rim if they weren't held tight together. I expect that being loose is how folks broke cast with snap on duals. Loose wheel can be awfully hard on cast hubs, as some of us learned in our younger years.
Hugh MacKay again
11-26-2006 09:05:50
Wardner: With text both above and below those photos I missed the bottom half. I think you will find modern day 18.4x34 duals are readily available. The spacer is welded only to the dual, in the first step down from edge of rim. In most cases you just replace the bolts holding inside rim to hub with bolts that have loop on the head. The J hook, hooks into that loop.
The reason I say these should be readily available is 30 years ago there were a lot of 34 inch duals on the go, yes even 10 years ago, out here in row crop country, the move lately has been to 42" and 46" tires. Around here you see a half dozen sets of those 34" and 38" duals floating around every auction. I am going scrap yard shopping in a few days, give me a shout, I can check out price, condition and availability. If someone has them, usually quite easy to spot.
Hugh MacKay
11-26-2006 08:44:52
Wardner: I had an idea you weren't concerned about cropping 300 acres. Do you have a copy of 150 Years of IH, by CH Wendel. He has a few photos in there of older Standard tractor with what looks like same system as your parts book.
Looking at your photos, I'm tempted to say your current wheel is different from that in the parts book.
billde
11-26-2006 06:54:13
Years ago my neighbor bought a 660 from the local power company, it had dual 24 inch rears. They looked just like M&W only the spacer ring was much heavier. He tried using them once, the turning radius was so big it just didn't work out. Power company used it with duals to lay cable.
Wardner
11-26-2006 07:27:36
 Re: Duals again in reply to billde, 11-26-2006 06:54:13
The 660 had three rear wheel options for rubber tires. A heavy and light wheel for 26" rims. They used 18 X 26 tires and were probably industrial although Nebraska tested a 660 with those tires. The parts book shows no dual adaptors for that size. The adaptors are only listed for the 18.4 X 34 setup.
Your neighbor's tractor must have been fitted with aftermarket duals although I suspect they were 26".
IH 560s didn't run the 34" rims. They were fitted with 26" and 30". There were no dual wheel adaptors for either.
billde
11-26-2006 08:01:38
 Re: Duals again in reply to Wardner, 11-26-2006 07:27:36
I believe they were 24.5x30 they were oddball rice tires. My point was that with duals it was not manuverable, the brakes just wouldn't hold to make power turns. The brakes are good enough to stop you or hold on an incline, but you will burn them out trying to turn in the field.
IHC-Farmall
11-26-2006 05:00:18
Could someone tell me how many were made? Were they Gas or Diesel?, did any of them have 4wd?
Thanks
Randy as in Randy-IA
11-26-2006 11:28:42
 Re: Duals again in reply to IHC-Farmall, 11-26-2006 05:00:18
Just shy of 7,000 made in gas , diesel and lp versions near as I can tell . I don't have a breakdown of how many of each .
Nat 2
11-25-2006 21:39:57
Good luck on finding those parts. I would imagine that they're extremely rare, given how rare 660s are in general.
A much less expensive, and far more easily procured solution would be "snap-on" type duals. Rings either thread on to the existing lugs, or bolt through those extra holes in the hub. Pretty much any 15-34 rim will work with the spacer ring and four clamps that hold the whole works together.
Wardner
11-26-2006 04:49:38
 Re: Duals again in reply to Nat 2, 11-25-2006 21:39:57
Yeah Nat, I think rarity is the key issue here. It wouldn't surprise me if the company only made prototypes and never received orders for the catalogued part.
If the Company did sell these conversions, what group of farmers might have bought them? What area and what crop would have seen duals on a 660? The window for buying the adaptors was probably limited to a few years. Bigger tractors were soon available and the investment would have gone to the bigger tractors instead of retrofitting the 660.
Narrowing down the area of use would make finding a set easier.
