engine out of 300u into an H
sunny 4 acres
11-25-2006 20:36:25
I was wondering if it is possible to put an engine from an H into a 300 utility? Can it be bol;ted right up or will modification be needed? Thanks for the help
Janicholson
11-27-2006 06:50:36
 Re: engine out of 300u into an H in reply to sunny 4 acres, 11-25-2006 20:36:25
There are minor issues such as the need to use the Us flywheel and front cover/gears and hydro pump to keep the Us systems happy, but it will work. There is a difference in HP so (if it were me ) I would upgrade the original 300 engine (unless cracked, or just worn to bits and a good buy on the H engine). JimN)
