Farmall B real axle seals
Stevie J. Mote
11-26-2006 00:27:20
Hello. I just purchased a 1947 Farmall B and it is leaking oil out the end of the rear axle. I think the seals are gone, but this is my first IHC tractor. I traded it for a John Deere A that I had. Please tell me what I need and where to get the parts to fix this problem. Your help is greatly appreciated. THANKS
gene bender
11-26-2006 04:17:42
 Re: Farmall B real axle seals in reply to Stevie J. Mote, 11-26-2006 00:27:20
Do mean the differental shaft as the lower one where the wheel bolts to is the axle and those hardly ever leak/ But the diff shaft going to the tranny sure get leaks. You should check underneath the tranny to see if front seal on the tranny leaks also also the inner diff shaft going to the tranny.
