460 carb is frosting up
Dan (wi)
11-27-2006 18:27:14
The carb on my 460 is frosting up,believe its problem with coil on intake/counter weight on exhaust manifold,whats the chance of replacing these parts if I can split the manifolds.thanx dan
ChadS
11-28-2006 09:18:17
 Re: 460 carb is frosting up in reply to Dan (wi) , 11-27-2006 18:27:14
Put in a larger venturi inthe carburator, that drops the manifold pressure (vacuum) slows the air down and does not get as cold as a smaller carb would. ChadS
old
11-27-2006 21:11:06
As Scott says its normal part of life and ALL engine do it, you just don't see it on cars/trucks. Thats why on cars and truck theres a tube that runs off the exhaust manifold going to the air cleaner to heat the carb intake air
MN Scott
11-27-2006 20:10:33
If its frost on the outside of the carb near the top its totally normal. You just notice it more at certain temps and humidity levels. Comes from the air being pulled thru the venturi of the carb at a vacum thus lowering the temp to cause frost.
Ted in NE
11-27-2006 19:08:32
Parts could be ordered from a CNH dealer last time I needed them. Unless the weight is broken on the cross shaft can usually free up the shaft & replace the spring. Will need to remove & seperate the manifold. Clean out the carbon and rust in the exhaust manifold above the carburator mounting. there are ports that let the exhaust heat that area untill the engine warms up. Even this don't solve the problem sometimes. Look in the archives, had a clever fix for this problem not to long ago. The bolts holding the manifold togather usually twist off & have to be drilled out
